jwpurdy
#1 Posted : Monday, October 25, 2010 7:21:33 PM(UTC)
jwpurdy
all of a sudden washer will not fill with water. not an electrical problem as everything else working ok
#2 Posted : Tuesday, October 26, 2010 1:35:09 AM(UTC)
Here are your parts, includes a wiring diagram
Replacement parts for MAYTAG MDBM601AWS Dishwasher - Undercounter | AppliancePartsPros.com
[COLOR="Blue"]not an electrical problem as everything else working ok[/COLOR]
I am assuming you mean that power to the control board is OK. The parts on the board that supply power to the fill valve may be shot.
Check the float on the overfill assembly. Sometimes it can get stuck in the up position. If it is then usually cleaning it will fix the problem.
If the overfill switch is being activated, check for 120 volts across the fill valve when it should be on.
If there is no voltage, check across the fill valve/overfill switch (they are wired in series).
If there is no voltage there, then the control board is probably toast.
If there is voltage, then check across the overfill switch. If there is voltage across the switch then the switch is shot.
If there is 120 volts across the fill valve then either the fill valve needs replacing or it's filter needs cleaning.
There is a screen filter built into the input side of the valve. Remove the valve from the unit and check/clean the screen filter.
Do not permanently remove the screen filter from the valve as it is there to keep crud out of the valve which could hold it open and cause a flood.
