rwiggin
#1 Posted : Monday, October 25, 2010 1:16:20 PM(UTC)
rwiggin
Recently replaced with belt bought thru Sears, lasted about 2 weeks. Fluke, or symptom of other problem?
magician59
#2 Posted : Monday, October 25, 2010 1:31:30 PM(UTC)
magician59
How easily does it turn by hand, without the belt?
rwiggin
#3 Posted : Monday, October 25, 2010 6:25:20 PM(UTC)
rwiggin
It seems to turn easily enough, a little awkward manipulating it from the bottom, but easy to turn tub. The belt looked burned.
magician59
#4 Posted : Monday, October 25, 2010 6:31:04 PM(UTC)
magician59
How easily can you turn the pump pulley?
rwiggin
#5 Posted : Tuesday, October 26, 2010 2:57:18 AM(UTC)
rwiggin
In lower position it seems to freewheel, in upper it starts a tad stiff then turns. I hope it's not a 242dollar transmission,"gulp". The small pulley below the motor turns easily.
rwiggin
#6 Posted : Tuesday, October 26, 2010 3:02:35 AM(UTC)
rwiggin
Read more: http://forum.appliancepartspros...p;p=292134#ixzz13SgpsYZT
http://forum.appliancepartspros.com
magician59
#7 Posted : Tuesday, October 26, 2010 7:18:01 AM(UTC)
magician59
Those are the only items that the belt drives. If you were able to freely spin them in both directions, it's possible you just got the wrong belt.
Part number: AP4035118
rwiggin
#8 Posted : Tuesday, October 26, 2010 10:32:46 AM(UTC)
rwiggin
That's what I ordered this time, thanks for your help,wish me luck.
Guest (5)
GE Dryer won't start/broken belt (Dryer Repair)
by dhmostyn 12/10/2012 5:31:42 PM(UTC)
broken belt (Washer Repair)
by pierre johnson 8/21/2010 7:26:24 AM(UTC)
washer stop spinning found broken belt underneath machine (Washer Repair)
by Gouri Ramnarace 8/12/2010 7:04:31 AM(UTC)
Broken Belt (Washer Repair)
by BRUCELOWE 6/11/2010 4:10:32 PM(UTC)
Amana washer broken belt, not turning, leaks from bottom (Washer Repair)
by JonTK 9/8/2009 9:13:04 AM(UTC)
by mpsals1111 7/19/2008 12:10:22 PM(UTC)
Whirlpool gas dryer won't turn, broken belt? (Dryer Repair)
by crusader66 6/22/2008 3:49:56 PM(UTC)
Broken belt (Washer Repair)
by Carlos 3/12/2008 2:42:59 PM(UTC)
Whirlpool broken belt (Washer Repair)
by hopeonceagain 10/16/2007 12:44:02 PM(UTC)
