Dishwasher is leaking from the front right bottom part of the dishwasher door. The gasket looks fine though depressed slightly in the right bottom corner. Any ideas??
My Triton XL has exactly the same problem - gasket replaced but still leaked, then repairman said "I guess I should take it apart" he took off the front metal panel of the washer and the answer was obvious - a strema of old soap and water coming down from the exhaust vent on the upper front right of the washer - he said he'd call back to see if he could fix it, but no word yet.
I had the same problem, called the repairman, who charged me $90 to remove the small plastic vent cover inside the door and rinse it out of soap residue. Try that.
