sandray68
#1 Posted : Friday, August 1, 2008 10:51:04 AM(UTC)
sandray68
Everything works, just doesn't heat anything. I have 120 VAC on the primary side of the big transformer under the magnetron so I suspected I had a bad magnetron. I ordered a new one from AppliancePartsPros (order # 417722) and installed it, but no change.
I appreciate any help you can give.
abadfish66
#2 Posted : Friday, August 1, 2008 10:59:39 AM(UTC)
abadfish66
Did you change the diode as well, if not you need to change it
sandray68
#3 Posted : Friday, August 1, 2008 11:09:38 AM(UTC)
sandray68
Thanks for your help, but I am not familiar with any diode associated with the magnetron. Also, there is not a diode listed in the critical parts list for service that came with the microwave. Is it on the smart board or a stand alone part?
abadfish66
#4 Posted : Friday, August 1, 2008 11:24:17 AM(UTC)
abadfish66
It is connected to the high voltage capacitor.
abadfish66
#5 Posted : Friday, August 1, 2008 11:25:29 AM(UTC)
abadfish66
sandray68
#6 Posted : Friday, August 1, 2008 5:45:11 PM(UTC)
sandray68
You were right! The diode was shorted out. Thanks for the part number. While I'm ordering this part and have the microwave unit all apart, are there any other parts you would recommend I replace on a 7-year old unit?
Thanks again.
abadfish66
#7 Posted : Friday, August 1, 2008 11:36:27 PM(UTC)
abadfish66
Nope, you should be good to go. Glad to help :)
cmar
#8 Posted : Saturday, August 2, 2008 5:50:47 AM(UTC)
cmar
my jvm1650wb001 just did this last night do I need to change both the magnetron and diode or just the diode?
sandray68
#9 Posted : Monday, August 11, 2008 2:38:13 PM(UTC)
sandray68
Received and installed the diode. Microwave works great now! Thanks for your expert help! My wife really appreciates it!:)
mgwhirlpool
#10 Posted : Monday, February 1, 2010 11:25:27 AM(UTC)
mgwhirlpool
TRY REPLACING THE DIODE ON IT IT LOOKS LIKE A FUSE.
Guest (5)
Microwave - no heat but all else ok (Microwave Repair)
by darter 11/5/2009 7:20:31 AM(UTC)
Frigidaire microwave - no heat. (Microwave Repair)
by Phalichanh 1/2/2009 10:13:25 AM(UTC)
Microwave - No heat electrical smell (Microwave Repair)
by Chase 7/27/2008 8:21:38 AM(UTC)
