mainzy
#1 Posted : Tuesday, July 29, 2008 1:54:02 PM(UTC)
mainzy
I am testing a sensor which is supposed to have a resistance of 1100 ohms. I switched to ohms,touched the probes together and zeroed my multimeter. then I inserted the probes into the sensor. The needle went one line above the 1.
This looks to me like 1.1ohms not 1100 would this be a correct assumption.
From right to left the numbers for ohms read 1,2,3,4,5,6,8,10,20,30,40,60,100,200,the last is1k and then the 8 on its side for infinity.
Thanks;Mainzy
#2 Posted : Wednesday, July 30, 2008 7:01:17 PM(UTC)
Originally Posted by: mainzy Go to Quoted Post
...I switched to ohms,touched the probes together and zeroed my multimeter...
On the Ohm scale you can see Rx1, Rx10, Rx100 etc. In what position is the range knob on you meter?
mainzy
#3 Posted : Wednesday, July 30, 2008 8:50:05 PM(UTC)
mainzy
The multimeter is a 19 dollar unit. There is only one place on it where you measure ohms. It is labeled ohm X1K.
#4 Posted : Thursday, July 31, 2008 11:55:24 AM(UTC)
Can you post a picture of this multimeter?
defrost heater not working but testing fine on multimeter (Refrigerator & Freezer Repair)
by doland 10/23/2022 11:10:02 PM(UTC)
test thermostat defrost whirlpool multimeter? (Refrigerator & Freezer Repair)
by riker1 9/19/2019 6:35:51 AM(UTC)
Using the Multimeter correctly to test lid switch? (Washer Repair)
by brian_h 10/27/2010 5:33:55 PM(UTC)
Can I test a Supco 3n1 with a multimeter? (Refrigerator & Freezer Repair)
by Pickngrin 9/26/2010 7:07:21 AM(UTC)
Digital multimeter fluctuations (Dryer Repair)
by Charles Burnette 7/7/2009 7:29:46 AM(UTC)
GE defrost timer operation (no multimeter) (Refrigerator & Freezer Repair)
by sgardner 5/14/2008 4:46:48 AM(UTC)
