jrob
#1 Posted : Monday, September 17, 2007 5:55:24 AM(UTC)
jrob
reset power by breaker comes on with PF in display clock is working all oven controls is dead checked all wiring connections looks good where would thermal fuse be on this unit? Or point me to the culprit.
Admin / APP Team
#2 Posted : Wednesday, September 19, 2007 12:03:08 PM(UTC)
Admin / APP Team
Rank: Administration
Here is a wiring diagram for your model. There are two thermostats on the back of the oven and a bi-metal thermostat under the top glass.
jrob
#3 Posted : Wednesday, September 19, 2007 12:40:19 PM(UTC)
jrob
are you saying the thermostats could cause this problem?
richappy
#4 Posted : Thursday, September 20, 2007 2:06:00 AM(UTC)
richappy
Check for 230 volts between the black and red wires to the control module. If ok, replace the control module. You will need to call appliancepartspros for part #, your number dosn't work for some reason
jrob
#5 Posted : Thursday, September 20, 2007 8:31:38 AM(UTC)
jrob
voltage coming to control module reads 245 volts taken at K5 Relay input
stove top works/clock on/oven controls dead (Oven Repair (including Ranges and Cooktops))
by jrob 10/10/2007 6:03:29 AM(UTC)
