meshow99
#1 Posted : Monday, October 11, 2010 10:18:15 AM(UTC)
meshow99
I had some scratching noises coming from the dryer and upon removing the front panel the teflon guides basically crumbled. I replaced the upper felt seal and since then I have had a very harsh vibration from time to time. This is usually not a problem immediately (with a wet heavy load). Once the load is lighter, the vibrations start. They start out as a barely noticible tremble, then develop into a violent burst. This happens at the same drum position each time.
Since then, I have replaced the rear bearing without positive results. Could I possible need a lower seal also? The belt and pully seem fine, and there is still a vibration when I add or reduce the pully tension. Any suggestions?:confused:
#2 Posted : Monday, October 11, 2010 1:52:05 PM(UTC)
I would replace the lower felt seal as well and check the blower wheel for a movements around the motor shaft.
- The lower felt seal Part number: AP2143044
- The blower wheel Part number: AP2106979
- The blower wheel clamp Part number: AP2146309
