I am working on a amana oven. I checked the hi limit, the fuse in the back panel and the element. No matter what i push it wont heat broil, bake convenction and so on. I believe its gonna be the power control board.. I hear one of the relays click but instantly clicks again. Just want to see what everyone thinks..
Originally Posted by: dmay21 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I am working on a amana oven. I checked the hi limit, the fuse in the back panel and the element. No matter what i push it wont heat broil, bake convenction and so on. I believe its gonna be the power control board.. I hear one of the relays click but instantly clicks again. Just want to see what everyone thinks.. D, I take for granted you did check for 240 VAC and broken or loose wires. With the checks you made and if you did check the wiring and voltage, Then I agree , start at the Relay Control Board, Part number: AP4280300
Good Luck, :cool: :cool: :cool:
I will try it and give you an update
Originally Posted by: dmay21 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I will try it and give you an update Ok, I'm pretty sure you'll fix it with the relay board. Will look for your update. Later, :cool: :cool: :cool:
