I want to remove & replace part # AP 2032265....Oven Bottom Panel. Is a proffessional person needed for this project?
Thank you for your help.
Originally Posted by: vinmaria ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I want to remove & replace part # AP 2032265....Oven Bottom Panel. Is a proffessional person needed for this project?
Thank you for your help. Vinmaria, No, a professional should not be needed for this repair. There are two screws in the rear corners of the panel, Loosen, do not remove the screws, and slide the screws towards the front of the oven. Raise the rear of the panel up, carefully, you can use a screwdriver in the slot in the center of the panel if you wish, and slide the panel back until the front flange clears the lip of the cavity bottom(1/2 inch or so). Transfer the two screws and tabs to the new panel, and reinstall reversed of the removal procedure. Good Luck, :) :) :)
