The right front burner would not always come on, when it did the flame was irregular and flames would come out of the air opening in the connecting tube. We replaced both the back and front burner, the back burner works fine, but the front burner still has the problem. What to do?
Originally Posted by: twarshavsky ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) The right front burner would not always come on, when it did the flame was irregular and flames would come out of the air opening in the connecting tube. We replaced both the back and front burner, the back burner works fine, but the front burner still has the problem. What to do? You should check the oriface (brass fitting that the burner tube encloses)for clogs, dirt, grease etc. If thats proper, you will need to replace the burner valve . Part number: AP4284817
Good Luck, :) :) :)
We did what you suggested and it worked. My husband still doesn't believe it was that simple. Thanks alot.:p
Originally Posted by: twarshavsky ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) We did what you suggested and it worked. My husband still doesn't believe it was that simple. Thanks alot.:p We're glad it was that simple, and happy that you're happy You're welcome, :D :D :D
