fixit33
#1 Posted : Monday, October 4, 2010 4:08:20 AM(UTC)
fixit33
Dryer will continue to run, in either auto or timer setting, but it will not turn itself off. The timer clock does not move, and the clothes will dry after 40-50 minutes. Does the timer need to be replaced or the thermostat? Is either part difficult to replace? Is there another reason for the dryer to not shut itself off??
#2 Posted : Monday, October 4, 2010 5:16:33 AM(UTC)
Replacement parts for DBXR463EG5WW models | AppliancePartsPros.com
Since the timer does not advance in timed dry or auto modes I would say that the timer is toast.
You could check this with a meter by measuring the voltage to the timer motor. If it is getting 120 volts and not advancing it is toast for sure.
If you do this be very careful as there is 240 volts a some of the connections on the timer and this is lethal!!!
Amana dryer will not shut off on automatic cycles (Dryer Repair)
by Nutforbriggs 4/21/2016 11:42:33 AM(UTC)
Maytag MDE7658BYW Timer not advancing/dryer will not shut off (Dryer Repair)
by countrybois 6/13/2014 10:47:30 AM(UTC)
Dryer will not shut off (Dryer Repair)
by patpeery@aol.com 11/22/2012 10:01:07 AM(UTC)
Whirlpool dryer will not shut off after new timer replacement (Dryer Repair)
by grayfeathers 10/23/2012 4:23:08 PM(UTC)
Dryer will not shut off in automatic cycle (Dryer Repair)
by jennarnott 6/21/2012 12:02:09 PM(UTC)
Dryer will not Shut off (Dryer Repair)
by Jeremybrutonsupply 5/25/2012 6:00:53 AM(UTC)
HELP! Dryer will not shut off & timer won't advance (Dryer Repair)
by csutliff 4/11/2012 10:17:10 AM(UTC)
Maytag Dryer Will Not Shut Off (Dryer Repair)
by MJScott 3/20/2012 11:35:17 AM(UTC)
Maytag Dryer Will Not Shut Off (Refrigerator & Freezer Repair)
by MJScott 3/20/2012 11:27:36 AM(UTC)
kenmore dryer will not shut off and will start when the timer is on zero (Dryer Repair)
by brettb 12/13/2011 4:05:19 PM(UTC)
LDG8414AAE Maytag Dryer will not shut off (Dryer Repair)
by skora 11/3/2011 11:42:33 AM(UTC)
by GWG 12/30/2010 7:53:55 AM(UTC)
Dryer will not shut off but heats ok (Dryer Repair)
by twilliams0204 12/16/2010 6:26:06 PM(UTC)
Dryer will not shut off. (Dryer Repair)
by jmkitson 8/5/2010 11:23:31 AM(UTC)
Amana Dryer will not shut off (Dryer Repair)
by kruczeric 6/8/2010 5:04:16 PM(UTC)
