My ignitor turns on then turns off. Its seems I have defective coils on the gas valve. I took off the vent (in the back of the dryer) but how do I reach the coils to replace them??? Please HELP!!! :confused:
You will need to pull front panel to get to the gas valve coils. If you have a meter, check the igniter resistance and current when turned on. Click on your model # for take apart help and part info.You will need to pull the drum belt for live test, just swing the door away and leave door switch wires connected.
I got the front panel open last night. I just ordered the coil kit, hopefully thats the issue. Thanks I'll keep you updated. :)
The coils came in yesterday and replacing them did the trick.
Thanks for your assistance. :)
:) *** Side note, parts came in ahead of schedule. That is exactly the kind of service you look for in these situations. *** :)
