207 Pages«<100101102103104>»
#1011 Posted : Wednesday, September 29, 2010 6:40:50 PM(UTC)
Originally Posted by: governor Go to Quoted Post
...there was only a light covering of frost...
John,
Did it cover the whole evaporator or just part of it?
Did you clean the condenser coils on the back of the refrigerator?
Are the both fans (in the freezer and next to the compressor) working?
#1012 Posted : Wednesday, September 29, 2010 6:45:56 PM(UTC)
Originally Posted by: nicehose Go to Quoted Post
hey gene,
seems you are the college of knowlege on this stuff..i am thankfull for that.
ive got a GE DSS25PFMDWW..
HERE THE PROB..I AM A NOVICE WHEN IT COME TO CHECKING CONTINUITY OF THERMOSTAT AND HEATER...IM ABOUT CERTIAN MY PROBLEM IS MY ADAPTIVE DEFROST BOARD..(COLD FREEZER , WARM FRIDGE , ICED OVER COILS) DUE TO A NEIGHBORS LIGHTNING STRIKE (MY GARAGE DOOR OPENERS FRIED) IM SURE THIS IS 1 +1 STUFF , BUT WHERE DO I PUT MY LEADS FROM METER TO EVAL HEATER AND THERM...BEFOR I REPLACE $100 BOARD THX
You do not have to take apart anything in the freezer in order to check the heater and thermostat. You can do it from the main control board. The instructions are on the page 3 of this thread, in the reply addressed to bohemian.
Here are the breakdown diagrams and Replacement parts for General Electric DSS25PFMDWW Refrigerator | AppliancePartsPros.com
governor
#1013 Posted : Wednesday, September 29, 2010 6:56:01 PM(UTC)
governor
John,
Entire evaporator was covered with thin coat of frost, I cleaned the condenser coils under the fridge with a vacum and air compressor last week, they are spotless. Both fans are running when they run. I am thinking something is intermitent here, I just checked and temp in fridge down to 38 now but it is empty and I know for sure evaporator has no ice at present time.
John
#1014 Posted : Wednesday, September 29, 2010 7:18:36 PM(UTC)
John,
It's very hard to say what is wrong at this time. Very strange behavior.
You have to keep the thermometers in both compartment and monitor the temperatures twice a day for a few days. Try not to open the doors too often and make sure the doors are not ajar.
governor
#1015 Posted : Thursday, September 30, 2010 5:13:56 AM(UTC)
governor
John,
I went a head and ordered new timer and thermostat from here, they were pretty inexpensive this way I will know everything has been replaced at least. Thanks for your help.
John
abcblah
#1016 Posted : Thursday, September 30, 2010 5:55:59 AM(UTC)
abcblah
There is no defrost timer in this refrigerator. Defrost cycle among all other futures controls by the main control board (#801 on the diagram). You can the instructions on the page 3 of this thread.
Here are the breakdown diagrams and Replacement parts for General Electric GSS25XSRESS Refrigerator | AppliancePartsPros.com
Thank you very much! I will definitely try out the instructions on page 3 =)
#1017 Posted : Thursday, September 30, 2010 4:31:08 PM(UTC)
John
You are welcome John. Keep us posted.
stevewong10
#1018 Posted : Thursday, September 30, 2010 7:41:30 PM(UTC)
stevewong10
Hi, I just found this forum and I'm trying to do these steps that are posted at the beginning of this thread:
"4). Using a flat screwdriver, slowly turn the shaft in the middle of the defrost timer clock wise until it clicks to switch from the cooling cycle to the defrost cycle."
"5). Wait about 10 to 15 minutes, open the freezer door and see if you can hear a sizzling noise. If you can, then the problem is the defrost timer which has to be replaced."
So, I did step 4 with no problem. The fridge stopped and I waited about 15 minutes. When I opened the freezer door, I don't think I heard the sizzling noise. I mean how loud is this noise suppose to be? I was expecting something like eggs frying or maybe Rice Crispies with milk and I didn't get that. So, I waited some more and checked about an hour later. I still didn't noticed the sizzling, but the fridge came back on and when I checked the defrost control, it had moved. Does that mean the problem is not with the defrost control and I should go to step 6? I did noticed that more water collected at the inside bottom of the fridge. Does that mean anything?
stevewong10
#1019 Posted : Friday, October 1, 2010 7:26:10 AM(UTC)
stevewong10
If the defrost control is OK, how do I get access to the defrost heater and the defrost thermostat? I took a look at the back and everything except the bottom is sealed. Do I get access to them from inside the freezer? Thanks.
#1020 Posted : Friday, October 1, 2010 6:10:03 PM(UTC)
What is wrong with your refrigerator?
Why do you believe there is something wrong with the defrost?
Here are the breakdown diagrams and Replacement parts for General Electric TBH18DATFRWH Refrigerator | AppliancePartsPros.com
Guest (10)
