Dear Tech,
No smell of gas inside oven, stove top working. Whern turning on R selector to qven and then L Temperature oven does not fire up.
Ignitor was changed successfully 4 months ago and oven worked therafter.
Diagram is on this web site. Thank you Frank
Originally Posted by: angie1754 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Dear Tech,
Diagram is on this web site. Thank you Frank Does the broiler work and heat ? Are you sure the new igniter is not the problem ? (loose connection, cracked broken igniter, etc.) Do you have a VOM multimeter so you can check for voltage to the bake igniter from the thermostat ? This is where we need to start , so we know what direction to take. :) :) :)
Joe M. Thank you
NO the broiler does not work and light/ heat up.
Remember I stated that I don`t think there is anything wrong with the ignitor because there is no smell of gas entering the area of the ignitor as was the case when I needed to change the ignitor 5 months ago.
Frank
Originally Posted by: angie1754 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Joe M. Thank you
Frank Frank, Check and make sure, your Clock is Not set in a Self Clean or Timed Bake, setting, by mistake, It has to be set in a Manual mode for the oven to operate, If that checks OK. You will need to check for 120 VAC across the 2 wires to the igniter(s), from the thermostat / control with the oven in a bake and broil settings, to determine if you have a broken wire or inoperative control. Good Luck, :) :) :)
