owens743
#1 Posted : Wednesday, September 29, 2010 7:58:38 PM(UTC)
owens743
About 3 days ago I noticed that the fridge wasn't cold and the freezer was defrosting. The freezer is now blowing out cool air and is frosting down the back wall and isn't freezing at all. We purchased the fridge brand new in 2001 and have had several things go wrong with it, too many to list. The last time it was repaired was in late 2005, with a similar problem. Some kind of board had to be replaced.
We had a service tech come out today and he said that the defrost board needed to be replaced. I was quoted $289. We don't want to keep putting money into this fridge. We need to know if this is something that we can fix ourselves or just get a new one. Any help with this will be appreciated.
#2 Posted : Thursday, September 30, 2010 1:13:48 AM(UTC)
Replacement parts for MAYTAG MSD2454GRW Ref - SXS/I&W | AppliancePartsPros.com
Here is a service manual
http://www.servicematters.com/maytag_library/docs/16010154.pdf
The parts shows that this unit has a defrost timer (Item 13 in Section 2) and not a adaptive defrost board, so first you have to which one it actually has.
If it is a defrost timer I can think of a number of reasons why the tech said "defrost board"
1. They did not do any troubleshooting and just assumed that the board failed. In this case I would not allow this person back to repair the unit as their service ability is poor at best.
2. The parts breakdown is incorrect. The unit is a late model in this units build and the timer has been replaced by a defrost board.
3. The service person misspoke and actually meant defrost timer.
I would confirm that it is a defrost problem. Remove the rear cover in the freezer section and check the evaporator coils. If they are heavily iced/frosted up then it is a defrost problem.
This can be cased by the timer/board, the heater or the defrost thermostat.
We need to know if it is a board or timer before proceeding.
owens743
#3 Posted : Thursday, September 30, 2010 10:25:58 AM(UTC)
owens743
Thank you so much!! You are correct. He didn't do any troubleshooting. The only thing he did was open the fridge door and check the temperature and open the freezer and said we had frost in it. The fridge was already pulled out and he didn't even look in the back. He wrote on the estimate sheet defrost board.
I checked the coils and they are covered in frost & ice. What now?
Originally Posted by: denman Go to Quoted Post
http://www.servicematters.com/m...ibrary/docs/16010154.pdf
#4 Posted : Thursday, September 30, 2010 11:34:20 AM(UTC)
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
Manually force a defrost cycle by turning the defrost timer cam (Item 13 in Section 2) till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element/thermostat combo (Item 13 in Section 4 ) from the wiring and measure it for continuity, usually around 20 ohms or so.
Note that the thremostsat opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
owens743
#5 Posted : Friday, October 1, 2010 7:23:45 AM(UTC)
owens743
I tried to manually force the defrost cycle, but it didn't work. After turning until I heard the 1st click, the fan & compressor went off and came back on after a couple of minutes. I did this several times with no result.
I then unplugged the fridge and found the wires for the heating element/ thermostat. I couldn't tell if the thermomstat was bulged, because it was incased in ice. I didn't get anything on the multimeter. I don't know if this is because something is bad or because I don't know what I'm doing. I'm not familiar with a multimeter. I'm not sure if I'm supposed to touch the outside of the wire or stick the leads inside the wires connector. I found some info online that said to take the negative lead and insert it into the orange wire/connector coming in from the back of fridge and postive into the heating element/thermostat connector. If this is correct, I didn't get a reading.
#6 Posted : Friday, October 1, 2010 7:47:07 AM(UTC)
[COLOR="Blue"]I tried to manually force the defrost cycle, but it didn't work. After turning until I heard the 1st click, the fan & compressor went off and came back on after a couple of minutes. I did this several times with no result.[/COLOR]
Does sound like the heater/thermostat combo needs replacing
[COLOR="Blue"]I didn't get anything on the multimeter. I don't know if this is because something is bad or because I don't know what I'm doing. I'm not familiar with a multimeter.[/COLOR]
FYI a multimeter is a fairly simple device. It has a battery when you measure ohms the voltage from that battery is applied to the device you are measuring and the the meter measures the current and then changes it to resistance.
I always short the ends of the meter leads together before measuring ohms. If you get a 0 you know that the meter is working.
[COLOR="Blue"] I'm not sure if I'm supposed to touch the outside of the wire or stick the leads inside the wires connector.[/COLOR]
You have to make contact with the metal connections so you have to stick the meter leads into the connector. If the lead tips are too big to reach the metal plugs in the connector stick a couple straightened paper clips, small nail etc. into the connector and then measure. Just make sure whatever you use do not touch each other.
[COLOR="Blue"]I found some info online that said to take the negative lead and insert it into the orange wire/connector coming in from the back of fridge and postive into the heating element/thermostat connector. If this is correct, I didn't get a reading.[/COLOR]
Not sure I understand the above.
Unplug the connector going to the heater/thermostat combo and measure across the contacts in the plug on the combo side.
owens743
#7 Posted : Wednesday, October 6, 2010 9:10:38 AM(UTC)
owens743
I got the part in yesterday and installed it myself ( with no help from my husband ) :) . So far, everything seems to be working. It was the heater that malfuctioned. The heating element was
fried & warped. Here's a pic, so that you can see. Thank you so much for your help.
UserPostedImage
#8 Posted : Wednesday, October 6, 2010 11:10:58 AM(UTC)
You are welcome
PS: The picture was definitely worth a thousand words.
Guest (7)
