i have a roper RT18DKXFN01 frost free fridge. Which direction is the evaporator fan supposed to spin? Long story but i had to take it off and put it back on and don't know if i hooked the leads back up correctly. if i reverse them, will it change direction? should the fan blow air into the freezer or draw air into the coils?
Originally Posted by: jperry1444 i have a roper RT18DKXFN01 frost free fridge. Which direction is the evaporator fan supposed to spin? Long story but i had to take it off and put it back on and don't know if i hooked the leads back up correctly. if i reverse them, will it change direction? should the fan blow air into the freezer or draw air into the coils? Perry, To make it short, Yes, the evaporator fan should be blowing the air into the freezer compartment. Yes, reversing the wires can cause the fan motor to run backwards. :cool: :cool: :cool:
Groups: Guests
My question is about a true commercial cooler that we replaced the inside box top fan. It’s blowing air up. Is that correct or was installed incorrectly reversing. Honestly there was no other way to connect it, like you could only connect it one way and it powers fine but we’re confused as to the airflow direction. Can you help clarify which way is the air flow is suppose to go. Thank you!
