nbrown9
#1 Posted : Monday, July 21, 2008 5:34:51 AM(UTC)
nbrown9
My Frigidaire stacking washer/dryer isn't spinning. I have already replaced the door lock switch as the toggle was broken off. I plugged the laundry centre back in and it will agitate but won't spin.
#2 Posted : Monday, July 21, 2008 8:08:58 PM(UTC)
The model number you posted does not come up. Verify and repost it, please.
nbrown9
#3 Posted : Tuesday, July 22, 2008 1:24:16 AM(UTC)
nbrown9
Model # GCET1041AS1 It is made by Electrolux. It is a stacked laundry team, full sized washer & dryer, Frigidaire gallery series if that helps.
#4 Posted : Wednesday, July 23, 2008 12:18:19 PM(UTC)
Is it American model? If it's not, we are not able to find any information (including a wiring diagrams) on-line.
nbrown9
#5 Posted : Wednesday, July 23, 2008 3:56:03 PM(UTC)
nbrown9
The label states its made by Electrolux Home Products Inc. out of Cambridge, Ontario, Canada. it also states it is made in the USA. There is also a serial #XE23802981 on the tag, if that helps with the model #. I was looking over the skematic and I noticed that it shows a capacitor which is in line with the wiring for the cams on the timer switch, that seem to be the circuits for the spin cycle. This capacitor seems to lead to the motor. I realize its hard to help without being able to view the skematic, but, is it possible that if this capacitor has failed in anyway, would it prevent the motor from starting on the spin cycle? As I stated before, it agitates fine and it did spin on one of the first loads after I replaced the lid lock switch, but now nothing. I read un some of the other threads, that some peolpe replaced the capacitor as well as the door lock switch. Just wondering if this model may have the same type of circuitry?
#6 Posted : Wednesday, July 23, 2008 5:16:01 PM(UTC)
Looks like this is a Canadian model and that's why it does not come up.
If you can post the wiring diagram, it might help to diagnose the problem. I do not think there is a capacitor issue.
nbrown9
#7 Posted : Monday, August 18, 2008 6:00:23 PM(UTC)
nbrown9
I ended up replacing the timer and the washer is working fine now.
Thanks for help anyway, Gene.
#8 Posted : Tuesday, August 19, 2008 12:35:51 PM(UTC)
I'm glad you were able to fix it.
Guest (6)
Maytag Legacy top load washer not spinning (Washer Repair)
by Guest 10/28/2023 8:56:04 AM(UTC)
Whirlpool washer Not spinning 6/21/23 (Washer Repair)
by yveron 6/21/2023 11:33:50 AM(UTC)
Whirlpool WTW4800BQ0 Washer Not Spinning (Washer Repair)
by MrTryToFixIt 12/1/2022 8:20:20 AM(UTC)
frigidaire washer not spinning out clothes (Washer Repair)
by tadthebass 3/24/2020 8:51:55 AM(UTC)
MAYTAG MHWC7500Y WASHER NOT SPINNING AT HIGH SPEED (Washer Repair)
by ehbrown1 11/5/2019 4:50:11 AM(UTC)
Stacked Maytag/Neptune Washer not spinning (Washer Repair)
by Building and Grounds 10/24/2017 12:26:37 PM(UTC)
GE Profile washer not spinning (Washer Repair)
by LSUStephen 7/16/2017 1:25:43 PM(UTC)
Whirlpool washer not spinning fast (Washer Repair)
by AmyM269 9/3/2016 4:22:47 PM(UTC)
Maytag Washer not spinning / draining (Washer Repair)
by retho78 5/21/2016 5:29:56 AM(UTC)
GE Washer not spinning (Washer Repair)
by zoobteach 8/29/2015 10:12:50 AM(UTC)
by atomicsynth 6/2/2015 10:36:31 PM(UTC)
Kenmore 70 Series washer not spinning (Washer Repair)
by workingdad 2/21/2015 7:31:47 PM(UTC)
Whirlpool washer not spinning or agitating; blowing breaker (Washer Repair)
by ejditz3 8/4/2014 1:15:39 PM(UTC)
GE washer not spinning any cycle (Washer Repair)
by j409 6/2/2014 7:44:19 AM(UTC)
Washer not spinning after replacing Thrust Bearing Kit (Washer Repair)
by Woody Williams 2/25/2014 2:06:33 PM(UTC)
