mlindsey3418
#1 Posted : Monday, September 27, 2010 10:05:18 AM(UTC)
mlindsey3418
I replaced the display part of my oven almost a year ago. It's started displaying error codes E6 and F2. The oven will work only when the error codes are displayed for a little while. Then it will shut off and the display will be blank. Then a little later the error codes will show up again. Do I need to replace the control panel or is there another part I can try? I noticed that you don't have the control panel in stock and they said you want be getting them in until 2011. I need it before then because the holidays are soon approaching. Thanks for your help!!!:) :)
Joe / APP Team
#2 Posted : Monday, September 27, 2010 11:33:09 AM(UTC)
Joe / APP Team
M,
That particular failure code (F2 E6) indicates a failure in the touchpad assembly, or a communication error between the control and touchpad assembly.
Part number: AP3131916
You may want to try cleaning the connector on the control board and the insertion end of the ribbon with alcohol or a contact cleaner, and insure the ribbon is set in the connector tightly.
Whirlpool Double oven diagnostic mode (Oven Repair (including Ranges and Cooktops))
by webjunk78230 8/29/2022 1:37:43 PM(UTC)
Whirlpool double oven RBD305PVS02 no display, no heat, lights work (Oven Repair (including Ranges and Cooktops))
by Guest 1/5/2022 7:05:37 AM(UTC)
Whirlpool Double Oven, RBD305PRS00, no display, oven dead (Oven Repair (including Ranges and Cooktops))
by steveg_nh 12/31/2021 7:23:33 AM(UTC)
Whirlpool double oven (Oven Repair (including Ranges and Cooktops))
by cwsunderland 4/4/2021 5:00:24 AM(UTC)
Whirlpool double oven RBD305PDQ14 (Oven Repair (including Ranges and Cooktops))
by ReeseReed0415 4/21/2020 7:15:22 AM(UTC)
Whirlpool double oven mounted in wall cabinets (Oven Repair (including Ranges and Cooktops))
by Redeyebob 12/30/2019 10:31:52 AM(UTC)
My whirlpool double oven won’t turn on (Oven Repair (including Ranges and Cooktops))
by Zuvdog 12/23/2019 8:38:06 AM(UTC)
Whirlpool Double Oven - Bottom Not Working (Oven Repair (including Ranges and Cooktops))
by kanderna 3/24/2018 9:58:57 AM(UTC)
Dead Display Whirlpool Double Oven (Oven Repair (including Ranges and Cooktops))
by chatenever 12/14/2017 6:51:55 AM(UTC)
Whirlpool Double Oven - Control Board & Door latch assembly??? (Oven Repair (including Ranges and Cooktops))
by Bhauer 6/6/2017 7:09:43 PM(UTC)
Whirlpool double oven display blank (Oven Repair (including Ranges and Cooktops))
by krupp 3/26/2016 7:01:29 AM(UTC)
How do I access control panel - Whirlpool double oven (Oven Repair (including Ranges and Cooktops))
by technogal54 3/6/2016 8:32:18 AM(UTC)
Whirlpool Double Oven Error Code - Help (E6 F2 and E1 F2) (Oven Repair (including Ranges and Cooktops))
by trvsthbdx 8/24/2015 7:46:08 PM(UTC)
Whirlpool Double Oven not working (Oven Repair (including Ranges and Cooktops))
by velazedv 6/16/2015 12:16:58 PM(UTC)
Whirlpool Double Oven Blank Display (Oven Repair (including Ranges and Cooktops))
by RDLearned 1/26/2015 3:20:49 PM(UTC)
