dadhann
#1 Posted : 14 years ago
dadhann
My dryer will not start when I push the button. Try all the "troubleshooting" suggestions and it still will not work. The light comes on when the door is open. Nothing happens when I push the start button. Thanks for the help.
#2 Posted : 14 years ago
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%208528192.pdf
What have you tried and how have you checked the various components?
When you push the start button does it make any noise?
dadhann
#3 Posted : 14 years ago
dadhann
The dryer makes no noise when the start button is pushed. Thanks for helping me.
#4 Posted : 14 years ago
Since the light goes on you have the voltage to run the motor.
Best and safest way to check components is with a meter.
The most common cause of your problem is a blown thermal fuse.
This is usually mounted on the blower assembly.
Unplug the unit and check the fuse with a meter should be 0 ohms.
Jiggery Pokery method is.
Unplug the unit.
Remove both wires from the fuse, short them together and tape them up so they will not short to the frame.
Plug the unit in and give it a try.
If blown, replace the fuse ASAP as it is a critical safety device re: prevents lint fires which can turn into house fires.
Also clean/check your vent system and the blower as these are the most common causes of it blowing.
Next would be the push-to-start switch and then the door switch.
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 9 months ago
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest about a year ago
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 2 years ago
Dryer Won't start - Repair Video (Dryer Repair)
by Guest 4 years ago
Kenmore 100 Series Dryer Won't Start (Dryer Repair)
by juser 4 years ago
Gas dryer won't start at all (Dryer Repair)
by GuyGreg 7 years ago
Dryer won't start (Dryer Repair)
by Ginadrc 7 years ago
by Petem 7 years ago
Maytag dryer won't start (Dryer Repair)
by eagle243 7 years ago
Dryer won't start after replacing the heating element (Dryer Repair)
by ivyholly 8 years ago
Dryer Won't Start-Lights Blinking (Dryer Repair)
by rleigh 8 years ago
Inglis dryer won't start (Dryer Repair)
by jkeefe 8 years ago
Amana Dryer won't start, but still gets hot (Dryer Repair)
by halfmoonranch 8 years ago
Dryer won't start (mid-troubleshooting, could use some help) (Dryer Repair)
by OUberLord 8 years ago
Whirlpool Dryer Won't Start (Dryer Repair)
by agjr200hp 8 years ago
