Akram
#1 Posted : 14 years ago
Akram
My washing machine is taking the water in constantly throughout the whole time and being overloaded with water. It does not even stop if I turn the machine off. But it would stop once I shut the water tap (that machine is connected to) down completely. And then it would start taking the water in again after I turn the machine on and open the water tap.
#2 Posted : 14 years ago
Replacement parts for MAYTAG MAH6700AWW Washer - Horizontal Axis | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/maytag_library/docs/16027053.pdf
Here is a manual to help with the repair
http://www.servicematters.com/maytag_library/docs/16026186.pdf
If the unit continues to fill when unplugged the water valve needs replacing.
