billychandler01@yahoo.com
#1 Posted : Wednesday, September 22, 2010 2:02:14 PM(UTC)
One day both oven and broiler stopped working at the same time?
#2 Posted : Wednesday, September 22, 2010 4:33:41 PM(UTC)
Does the control work?
What happens if you try to input anything?
How are the surface burners working?
We need as much as possible description on the problem.
#3 Posted : Thursday, September 23, 2010 10:39:24 AM(UTC)
Sorry, yes all controls and stove top burners working as designed.
Thanks, Bill
#4 Posted : Thursday, September 23, 2010 5:36:45 PM(UTC)
Bill,
Check for 120 VAC to the Bake igniter while the control calls for Bake and, to the Broil igniter while the control calls for Broil. Post the results.
Here are the breakdown diagrams and Replacement parts for AMANA ACS3350AS Range - S/c S/i Gas | AppliancePartsPros.com
#5 Posted : Tuesday, October 19, 2010 9:20:31 AM(UTC)
I replaced oven igniter because it sounded like the correct repair, still not working. Two questions, since both the oven and broiler are inop and if both igniters were bad do you have to replace both for one to work. and second question, when wiring oven igniter since the two wires are not colored or identified in anyway does it matter which wire is wired to which?
Bill
#6 Posted : Tuesday, October 19, 2010 9:36:54 AM(UTC)
Hi Gene,
sorry one more thing that may help that I forgot, the oven and broiler did light intermitintley, only twice out of twenty tries before I replaced igniter.
Bill
#7 Posted : Thursday, October 21, 2010 7:32:57 AM(UTC)
oven inop
Bill
Read more: http://forum.appliancepartspros...-inop.html#ixzz130XwjvEC
http://forum.appliancepartspros.com
#8 Posted : Saturday, October 23, 2010 4:20:39 PM(UTC)
Bill,
Bill,
Did you do this simple test?
If you did, what is the result?
I'm not able to do it myself and without it I can not proceed further.
#9 Posted : Thursday, October 28, 2010 8:11:20 AM(UTC)
I do not have a meter but I can get one, that was why I did not do that test and I hoped replacing the igniter would work since it sounded like the most likely repair and it was over 5 years old. I will do the test and post results, thanks for your help.
Bill
Guest (5)
Tappan Oven and broiler inop (Oven Repair (including Ranges and Cooktops))
by RDSDoug 1/15/2011 9:41:18 AM(UTC)
Oven and Broiler Inop (Oven Repair (including Ranges and Cooktops))
by LouisC 5/26/2008 6:53:17 PM(UTC)
