AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Washer Beeps thru cycle and after load is done until led is lifted
Washing machine beeps every 2 minutes the entire time while the washer is working. It will keep beeping until it is turned off or until the lid is lifted. It also some time will not go to the proper cycle, when I try to put it on anything but the normal cycle and try to change the water type or anything else it will automatically take it to the 60 minute cleaning (which by the way I have already done)....Please help!!!!!:) Washer is only a little over 1 year old.
It sounds like a bad electronic module. Click on your model # above and order the part listed. Part # AP3175691 Also your exact model # doesn't show up so check with supplier check before ordering
Boston, Did you get this problem resolved??? I have a similar issue. Just wondering if the electronic module fix the beeps????
Washer Repair
