30 Pages«<34567>»
#41 Posted : Monday, July 21, 2008 5:28:00 PM(UTC)
Keep us posted.
RocketRepair
#42 Posted : Saturday, August 2, 2008 7:44:36 PM(UTC)
RocketRepair
Model:GSL25JFRF BS
Serial:GH217579
Is this one covered for a mother board replacement?
What do you do when no service and repair manual is available?
#43 Posted : Monday, August 4, 2008 12:47:45 PM(UTC)
Hi RocketRepair,
What exactly is wrong with your refrigerator?
bristol
#44 Posted : Tuesday, August 5, 2008 5:47:54 AM(UTC)
bristol
Model: GE PFS22SBSBSS Serial #: AL059537 Purchased 04/2006
Control Board: GECP DOM - EBX1069P005 WKKT Model No.: 0158-04-03
GEA Part No.: 200D4860G015
I have a problem similar to dokken. Condensor fan spins slowly or not at all. Measured 13.5 VDC at pin 8 on J2 and 4 VDC at pin 5 on J2. Unplugged fan and pin 5 went to 13.5 VDC. Cooled condensor with external fan and pin 2 dropped slowly from 0.4 VDC to 0.0 VDC after condensor shut off. Voltage at pin 4 (evap motor) at 10.15 VDC also dropped slowly to 0.0 VDC after condensor shut off. I called GE consumer relations (800 386 1215) and after navigating through their system, I was told that there would be no cost for service call and board replacement.
seveneven
#45 Posted : Thursday, August 21, 2008 1:48:43 PM(UTC)
seveneven
Hi there, I found this forum last night after my fridge started clicking every five seconds and warming up. :(
The building I live in is not yet two years old (same goes for the appliances). This morning when I spoke with the building manager to see if anyone else had the same issue, she said that hers started clicking a few weeks ago. The problem (just like this forum suggests) was the control board, which needed to be replaced at a cost of about $300.
Abadfish66, if you are still out there, could you tell me if my board would be covered under warranty, or what the replacement part number would be? (Model: GDS20KBSBBB)
Also, what does one need to say, or who should one talk to in order to get this warranty??
abadfish66
#46 Posted : Thursday, August 21, 2008 1:59:50 PM(UTC)
abadfish66
Seveneven...Your board is covered and will be replaced free of charge as long as it's under 3 years old. Just call GE at 1-800-432-2737 and schedule a repair, let them know it is a no cool refer and they will get someone there asap. No need to mention anything to them about any thing other than that. The call takers do not have the info I do, but the service tech that comes out will, so you are good to go. Hope that helps.
abadfish66
#47 Posted : Thursday, August 21, 2008 2:01:49 PM(UTC)
abadfish66
Not sure about your building managers refer. If hers did not fall under the model# and serial# range then she got charged correctly.
seveneven
#48 Posted : Thursday, August 21, 2008 2:13:53 PM(UTC)
seveneven
Abadfish66...thanks for the fast response!
I'm in Canada - will that exclude me from warranty coverage? My building manager contacted Mabe at 1-800-361-3400 (which was the contact info listed on the refer manual). If I contact GE directly using the number you listed, will I stand a better chance?
abadfish66
#49 Posted : Thursday, August 21, 2008 2:47:08 PM(UTC)
abadfish66
I don't know how that would work, all the warranty info says for the United States only and all I have is based in the USA. Don't you guys up there use 240 volts to run refrigerators there? I know GE manufactures refers for Canada, and they are 240 volts.
seveneven
#50 Posted : Thursday, August 21, 2008 3:09:04 PM(UTC)
seveneven
Hmmm...well the fridge I've got is 120V. Maybe 240V is used for older buildings?
I guess that I will contact GE Canada and see what they say...thanks for your help! If you come across any warranty lists for Canada, let me know... :)
Guest (18)
30 Pages«<34567>»
