ctralw
#1 Posted : Monday, September 20, 2010 4:24:27 PM(UTC)
ctralw
My kitchenaid KUDT03STSS2 dishwasher won't turn on. The lights won't turn on. It is like it quite in the middle of a cycle. The front panel screws weren't tight so it was leaking water out. We stopped it, tightened up the front panel screws and then it wouldn't start back up again.
Thanks in advance for your help!
bigger-hammer
#2 Posted : Monday, September 20, 2010 8:53:07 PM(UTC)
bigger-hammer
First thing i would do is check the breaker. If water leaked in through the loose panel, it may have shorted out one of the components in the door. (door switch, elec. timer, touch pad, etc). Hopefully the breaker killed the power fast enough before the water fried something. I couldn't see a pic on the part section but i'm pretty sure this model has a thermal fuse mounted on the main elec. control board. If that fuse blew it would also kill the power to the whole unit. After you make sure the power is OFF you can do continuity test on that fuse
