2 Pages12>
jetmech
#1 Posted : Monday, July 21, 2008 10:31:47 AM(UTC)
jetmech
My Hotpoint gas oven won't heat compleatly to baking temps. I don't
think it is getting over 200F. I have checked resistance to the oven
sensor and it is 1089 ohms from the connector at the circuit board with
the connector removed. It should check at 1100 ohms + or - 20. This
should put it in range. However with the connector connected to the circuit board it only reads 970 ohms. Does this mean the sensor is bad,
the circuit board is bad or neither?
abadfish66
#2 Posted : Monday, July 21, 2008 10:39:01 AM(UTC)
abadfish66
First thing I would do is cut out the connector at the sensor and hardwire it. Sometimes that connector can be bad. Then check resistance back at the board.
jetmech
#3 Posted : Monday, July 21, 2008 11:26:06 AM(UTC)
jetmech
It does the same hard wired. With the sensor wires off, resistance between the pins 4 and 5 of the circuit board is about 8700 ohms.
abadfish66
#4 Posted : Monday, July 21, 2008 12:26:42 PM(UTC)
abadfish66
With the plug removed from the board resistance between the 2 white wires is 8700 ohms? If thats the case the sensor is bad.
jetmech
#5 Posted : Monday, July 21, 2008 3:01:17 PM(UTC)
jetmech
No,the resistance of the two circuit board pins is 8700 ohms. The resistance of the sensor from the connector that plugs in to the board
is 1089 ohms. I guess what I need to know is do I check sensor resistance
with the plug connected or disconnected?
abadfish66
#6 Posted : Monday, July 21, 2008 3:20:24 PM(UTC)
abadfish66
Check resistance with plug disconnected, 2 white wires. Your sensor is fine if you have 1089ohms.
If it will only get to 200degrees, check the resistance of the bake element with wires removed, same for the broil element, post results.. Also check to make sure you have 120 volts red to white and 120 volts black to white and 240 volts red to black at the terminal block where the power cord connects to the range.
jetmech
#7 Posted : Monday, July 21, 2008 5:49:12 PM(UTC)
jetmech
This is a gas oven.
jetmech
#8 Posted : Wednesday, July 23, 2008 11:52:22 AM(UTC)
jetmech
Ok, this is a model number RGB746HED3WH. The oven lights up with the orange glow under the bottom plate in less than 60 seconds. The broiler
lights up in less than 60 seconds as well. The sensor has 1089 ohms measured
from the plug that connects it to the control board. What do I do next?
abadfish66
#9 Posted : Wednesday, July 23, 2008 11:56:58 AM(UTC)
abadfish66
When you say lghts up I assume you mean the glowbar comes on and lights the gas to the bake and broil tubes, do you notice if the gas stays lit on the bake burner, or does it go out and come back on constantly? I would check the resistance of your bake glowbar, should be between 50-150ohms
jetmech
#10 Posted : Thursday, July 24, 2008 12:33:13 PM(UTC)
jetmech
I got 202 ohms on the bake glowbar.
2 Pages12>
