3 Pages123>
fhon7964
#1 Posted : Friday, September 25, 2009 4:31:38 PM(UTC)
fhon7964
We have a russell range cooketop, 36-6 and are looking for the spark module. The original spark module(Kool lite #6521) is not working and we need to find a replacement. Any ideas? We can not find Russel Ranges or Kool Lite.
thank you
SuzeR
#2 Posted : Thursday, September 16, 2010 9:08:34 AM(UTC)
SuzeR
I also have a six-burner of indeterminate age, and needed two new ignitors - the dacor ranges use EXACTLY the same units and everything now works perfectly. My tech guy showed me how to blow out the gas pipes as they get filled with dust and grime over time and therefore not as much gas flows through. I'm ready to get rid of the remaining enamel on the grates and am having it all blasted off and the underlying iron sealed. It's as good as new!
yvonneinfayette
#3 Posted : Sunday, September 19, 2010 7:26:01 PM(UTC)
yvonneinfayette
Do either of you have a copy of the Owner's Manual for the Russell Range? We just bought a foreclosure, which has this 6 burner Russell cooktop. Unfortunately all the owner's manuals are gone. Cannot find anything online. Also cannot find new drip pans. The old ones are beyond disgusting. Any suggestions?
SuzeR
#4 Posted : Sunday, September 19, 2010 7:36:50 PM(UTC)
SuzeR
I don't think I ever had a manual either..... But it's a pretty straight forward cooktop. Everything is designed to come apart very easily so don't be afraid to do that as there is probably quite a bit of dust in the gas ducts. Take them out as horizontally as possible and then tip into a garbage can. I have not looked for replacement drip pans, I scoured mine with wire wool to get rid of the grime. Totally worth it all....
yvonneinfayette
#5 Posted : Sunday, September 19, 2010 7:43:15 PM(UTC)
yvonneinfayette
I just read somewhere else that it uses the same parts as a dacor.... if that helps.
yvonneinfayette
#6 Posted : Sunday, September 19, 2010 7:44:19 PM(UTC)
yvonneinfayette
Suze, thanks for the info. will try that to get the dust out. have you had the top grates re-enameled?
SuzeR
#7 Posted : Sunday, September 19, 2010 7:49:01 PM(UTC)
SuzeR
I'm having the enamel removed and the bare metal sealed. Enamel always chips because of the heat and scraping from pots & pans - looks good in the showroom only IMO
Erinsheff
#8 Posted : Saturday, January 8, 2011 6:34:43 AM(UTC)
Erinsheff
Suze.....
where did you get the enamel removed and the grates sealed (what kind of store/business)? We just bought a house and it has a Russell Range. I love it but the grates are in poor shape and the drip pans look horrible! I am going to try to scour the drip pans like you suggested, but I need to figure out what to do with the grates.
Thanks so much!
chromisdesigns
#9 Posted : Sunday, January 9, 2011 11:00:22 PM(UTC)
chromisdesigns
check online or your local yellow pages for antique/vintage stove repair. There will be someone who can get the burners re-enameled. Which I encourage, by the way. If you let them get down to the bare iron, they rust like mad if you keep them clean, otherwise they have to stay greasy.
However, if you do have them bare, here's a tip for cleaning them up -- run them through the self-clean cycle on your oven. Then let them cool completely without opening the oven door, so there is no chance of warping. I've done ours this way, they come out spotless. But then, you need to give them a light coat of oil and burn it in over the flames for a half-hour or so, or they will flash rust.
We also have the Russell char-grill, and that's how I clean the grill grates, as well.
Good luck finding new drip pans the right size -- I haven't been able to locate a source. If you do, please post it here. If mine ever get bad enough, I'm going to check with a local sheet metal or metal-spinning shop about making replacements. I can't imagine it would be too costly to have it done, they are just stamped and/or spun stainless sheet.
That said, if they are really bad, try some degreasing solvent and green scotchbrite (outside), or have them sandblasted to a matte finish. They are very heavy guage sheet, so even sandblasting shouldn't wear them too much, it will just result in a clean, matte finish, rather than polished. I have a big metal polishing lathe (like a big bench grinder), and when we first got our house, I cleaned the pans with a scotch-brite wheel and then mirror polished them. But they don't stay that way, of course!
mcurran74
#10 Posted : Wednesday, March 2, 2011 3:29:10 PM(UTC)
mcurran74
Has anyone know where you can get the grates for a 6 burner Russell Range?
Guest (6)
3 Pages123>
