Hello,
My refregerator keeps dispensing water. I went to open the freezer door and then closed it and all of a sudden water just started dispensing. The switch is currently on ICE, but water keeps dispensing. It will only stop when the freezer door is left open. As soon as I press the switch as if the door is closed, water starts dispensing. I have tried unplugging the refrigerator and also using the lock button, but nothing seems to work. I have shut the water off. However, you still hear a hum as if it's trying to dispense the water. Any ideas what could be causing the issue? Thanks in advance for the assistance.
