larry ryan
#1 Posted : Saturday, July 19, 2008 6:15:02 AM(UTC)
larry ryan
The serial # is MR638602Q
This is a GE double oven with manual knob controls for the lower oven which works fine when we trun the electrical breaker on.
The upper oven is controlled by a control panel which has been showing a F7 error code.
About a year ago when this accured the repair man turned the power off and waited about 5 min. then turnen the power on which cleared the code and everything has been working fine till a few ddays ago.
The F7 error code has accured again along with a flashing set light and a lot of beeping.
The repair tech now tells me i need a new control panel but can't tell me what the F7 error code means.
Questions-
What does the F7 error code mean.
Should I replace the entire control panel.
What would be the part or parts I need.
What would be the cost.
Thanks--Shadow28:confused:
abadfish66
#2 Posted : Saturday, July 19, 2008 8:14:49 AM(UTC)
abadfish66
An F7 code means a stuck key pad on the panel. You will need to replace the keypanel. Cost generally runs $200-$300 for the part.
GE Oven Control board locking after starting oven. Model # CGS985SETASS (Oven Repair (including Ranges and Cooktops))
by Mike I 1/15/2024 10:55:45 PM(UTC)
GE Oven Control Board (Oven Repair (including Ranges and Cooktops))
by BillDiesel 12/5/2017 7:36:41 AM(UTC)
Please help me identify this GE Oven Control Board! (Oven Repair (including Ranges and Cooktops))
by PHRoberts 2/13/2008 8:16:56 PM(UTC)
