maserom
#1 Posted : Tuesday, July 15, 2008 11:38:40 AM(UTC)
maserom
Just curious how difficult it is to replace the computer touch panel on this oven. Any steps or advice on replacing this part would be greatly appreciated.
Thank you
johnmou
#2 Posted : Thursday, July 17, 2008 4:44:03 PM(UTC)
johnmou
Why do you need to change? It's easy, but it may not solve your problem. You might be the No. 4 victim. Check out others in this forum.
johnmou
#3 Posted : Friday, July 18, 2008 8:32:18 PM(UTC)
johnmou
Got any answer yet? File your complain to following first.
http://www.whirlpool.com/custserv/email_form.jsp
to remove the control assambly:
1. remove the four knobs.
2. remove the 6 screws at bottom of the control panel (above door).
3. remove 1 screw from each end of control panel (slide the range out about 3 inch).
4.try to tilt out the whole panel from bottom, the top is hook on the top black surface. (you might need to remove the both end cap during tilt out to move up)
5. un-plug the connector from back. (there are 3 connectors)
Good luck!
