2 Pages12>
H. B. TEMPLE
#1 Posted : Wednesday, September 8, 2010 7:40:47 AM(UTC)
H. B. TEMPLE
Ice Dispencer Locked On "crushed". Water Dispencer Ok.
#2 Posted : Wednesday, September 8, 2010 10:56:32 AM(UTC)
Remove the ice container and the motor cover. Check the solenoid (#378 on the diagram) for continuity.
- The solenoid assembly Part number: AP2071947
If the solenoid is good, check for 120 VAC to the solenoid by pushing the ice release lever with the door switch taped in and the ice cubes selected. Post the results.
Here are the breakdown diagrams and Replacement parts for General Electric DSS25KGRDWW Refrigerator | AppliancePartsPros.com
jwgoodman
#3 Posted : Wednesday, September 15, 2010 1:30:14 PM(UTC)
jwgoodman
Could this be the same issue with frigidaire..I am experiencing the same issue?
#4 Posted : Wednesday, September 15, 2010 3:52:59 PM(UTC)
Yes, it could. What is the complete model number of the refrigerator?
jwgoodman
#5 Posted : Thursday, September 16, 2010 6:41:31 AM(UTC)
jwgoodman
Model: GLRS267ZDB2
Serial: LA44905688
#6 Posted : Friday, September 17, 2010 1:24:23 PM(UTC)
Model: GLRS267ZDB2
Serial: LA44905688
You have to perform exactly the same troubleshooting.
The solenoid is shown as #45 on the diagram.
- The solenoid assembly Part number: AP3965560
EL Nobles
#7 Posted : Monday, August 2, 2021 11:28:17 AM(UTC)
Guest
1. Take out the ice bin to access the switch in the freezer.
2. Underneath the ice bin is a metal rod.
3. In the back of the freezer there is a square hole from where the rod came. Put your finger in this
hole.
4. You should feel a plastic lever. If it's up, push it down. If it's down, push it up.
5. Put the ice bin back and try for ice again. You should receive crushed and cubed ice at this time.
6. If you push the lever up or down and it doesn't stay in place we may need to schedule service.
thanks 1 user thanked Guest for this useful post.
Mastoo on 9/10/2021(UTC)
Guest
#8 Posted : Thursday, August 12, 2021 6:17:02 PM(UTC)
Guest
It works!!! Thank you so much!!
Guest
#9 Posted : Friday, September 10, 2021 7:40:44 PM(UTC)
Guest
Wow, it fixed mine too. Where can we send your service fee?
Guest
#10 Posted : Friday, October 29, 2021 3:47:51 AM(UTC)
Guest
hole.
Solid advice!!! It worked. Much appreciated.
KITCHENAID ICE DISPENCER STUCK (Refrigerator & Freezer Repair)
by Guest 8/15/2021 4:57:12 PM(UTC)
Ice Dispencer stops dispencing (Refrigerator & Freezer Repair)
by jmclanton 5/29/2012 10:03:40 AM(UTC)
ice dispencer (Refrigerator & Freezer Repair)
by eduardoalmoite 5/26/2012 12:28:12 AM(UTC)
by eduardoalmoite 5/25/2012 11:50:30 PM(UTC)
Water/Ice Dispencer not working (Refrigerator & Freezer Repair)
by Jeff G. 3/20/2012 5:58:24 AM(UTC)
Ice dispencer not working (Refrigerator & Freezer Repair)
by richmoralesinlincoln 2/27/2012 9:20:38 AM(UTC)
Ice Dispencer Switch (Refrigerator & Freezer Repair)
by H. B. TEMPLE 9/8/2010 7:52:23 AM(UTC)
Ice dispencer not crushing ice (Refrigerator & Freezer Repair)
by michaelrx 7/12/2010 12:51:02 PM(UTC)
Ice Dispencer Door Flap Does Not Close (Refrigerator & Freezer Repair)
by jakL357 8/28/2009 12:46:27 PM(UTC)
Ice Dispencer Door (Refrigerator & Freezer Repair)
by MALIK1 6/22/2009 8:12:04 PM(UTC)
by steve250f 4/8/2009 9:25:00 AM(UTC)
ICe dispencer will not rotate (Refrigerator & Freezer Repair)
by m218perez 10/27/2008 3:37:21 PM(UTC)
GE Ice dispencer working intermittently. (Refrigerator & Freezer Repair)
by Bill D 3/1/2008 3:15:58 PM(UTC)
2 Pages12>
