edsel58
#1 Posted : Thursday, July 17, 2008 2:59:36 PM(UTC)
edsel58
I have a Kenmore oven - model # 911.48489991. I am replacing the control board (ERC). The original board is a Sears# WB27T0051 / RobertShaw GEA# 191D1575P009. The new board is a GE replacement # WB27T10282 (Torisan 2063600047).
The wiring configuration on the new board is different, and the included instructions are blurry and are not very informative.
Does anyone have better instructions or information on this?
Thanks!
Warren
#2 Posted : Thursday, July 17, 2008 6:31:59 PM(UTC)
Hi Warren,
I hope the information and instructions from one of our previous posts will help you: http://forum.appliancepartspros...es-extra-wire-loose.html
edsel58
#3 Posted : Friday, July 18, 2008 7:55:33 AM(UTC)
edsel58
Hi Gene,
The info on the other post helped a lot! Thanks both to you and the original "poster".
BTW, the oven works again!
Warren
#4 Posted : Friday, July 18, 2008 12:05:08 PM(UTC)
Warren,
I'm glad you were able to fix it.
jfrost
#5 Posted : Friday, December 18, 2009 7:20:18 PM(UTC)
jfrost
I just got the same part but no diagram to help me convert over to the new set-up. Can someone post a copy of the diagram they gave for the new part. Also, What did you do with the two small harnesses that whent from a 6 plug set-up to a 8 plug? Thank you
