Hunter30
#1 Posted : Tuesday, September 14, 2010 11:16:12 AM(UTC)
Hunter30
Hi I have a Norge # LWN203W that had been in storage for about 4 years it will not agitate I checked the water level control line and it had a hole in it I removed the bad section and re-connected everything still no agitating but if I blow on the line the machine start to agitate could the WLC switch be bad? Also the WLC line is now shorter would that make a diff?
Thanks in advance
C C
Joe / APP Team
#2 Posted : Tuesday, September 14, 2010 12:00:53 PM(UTC)
Joe / APP Team
Thanks in advance
C C
CC,
First things first,
Replace the air dome hose,
Part number: AP4025726
The water level control is not the problem, at this point, if It agitates when you blew in it, the switch and wiring are OK.
You could have a clog in the bellows or the bellows opening.
(where the air dome attaches to the outer tub assembly).
Repalce the hose and check the opening on the bellows and we'll go from there.
Good Luck,
Hunter30
#3 Posted : Tuesday, September 14, 2010 12:23:12 PM(UTC)
Hunter30
Thanks Will do
Joe / APP Team
#4 Posted : Tuesday, September 14, 2010 1:19:13 PM(UTC)
Joe / APP Team
Thanks Will do
Hunter,
You still could have a bad water level switch.
But you need to get that hose replaced and openning checked for safety reasons, more than anything else,
That machine could overfill and flood the house, if left in the present condition.
Have you run a tetst cycle, does the machine spin, can you hear the pump sucking air, does the water fill ?
Drop us a line if you need more help,
:cool: :cool: :cool:
Hunter30
#5 Posted : Tuesday, September 14, 2010 1:44:17 PM(UTC)
Hunter30
Yes it fills and spins and drains with no problem I will replace the hose and check the opening
THANKS
Joe / APP Team
#6 Posted : Tuesday, September 14, 2010 2:05:11 PM(UTC)
Joe / APP Team
THANKS
Hunter,
OK, great.
Drop us a line, when you're done.
Hunter30
#7 Posted : Tuesday, September 14, 2010 5:15:33 PM(UTC)
Hunter30
Changed the hose still doing the same thing blew back away from the pressure switch no restrictions connected the line back to the pressure switch and blew and it started agiating for as long as I blew on it. Let it run through all other cycles and it did fine but no agiation.
Thanks in advance
Joe / APP Team
#8 Posted : Wednesday, September 15, 2010 5:52:25 AM(UTC)
Joe / APP Team
Thanks in advance
Hunter,
As long as you're sure there are no air leaks on the new air dome tube,
You're going to need the Water Level Switch.
Ther must be a mechanical failure inside the switch.
Part number: AP4025680
Good Luck,
:) :cool: :)
Hunter30
#9 Posted : Saturday, September 18, 2010 4:19:32 PM(UTC)
Hunter30
Replaced the switch everything is working fine thanks for all of your help.
C C
Joe / APP Team
#10 Posted: : Monday, September 20, 2010 5:12:54 AM(UTC)
Joe / APP Team
C C
C C,
Glad to hear that,
You're welcome,
water level control (Dishwasher Repair)
by pfoxharp 12/29/2017 7:15:54 AM(UTC)
Water level control (Washer Repair)
by FLDAVE 12/8/2013 12:43:39 PM(UTC)
water level control kaput? Kenmore portable washer (Washer Repair)
by damenefee 10/25/2011 10:18:54 AM(UTC)
Installing Whirlpool water level control (Washer Repair)
by nnieser 3/27/2011 6:28:56 AM(UTC)
timer control or water level control? (Washer Repair)
by Elehairyjob5 2/18/2010 6:13:30 AM(UTC)
which part do I need for water level control so washer does not over fill? (Washer Repair)
by Paul Bailey 8/13/2009 2:10:21 PM(UTC)
by johnnybnice 5/13/2009 7:16:01 PM(UTC)
Water Level Control does not work (Washer Repair)
by darkhorse 8/30/2008 4:21:25 PM(UTC)
