2 Pages12>
tino2003
#1 Posted : Wednesday, July 16, 2008 12:06:20 PM(UTC)
tino2003
I have a Magic Chef Model No. CTN1511GEW problem is frost build up. I have tried everything I can think of and the frost build up continues. I have defrosted the freezer using a hair dryer but careful not to heat it at any section of the frost for too long. On reconnecting the electrical cord to the outlet the refrigerator works perfectly and runs for 6 hours then shuts of. I don’t know how many minutes before restarting because the compressor is very quite and I don hear it. But it stopped again after 3 hours and works normal after that but after 3 to 4 days the frost starts building up.
I don’t know if it is the defrost heater, defrost thermostat or defrost timer. I know how all these items look but I cannot find a defrost timer. I don’t know what can go wrong on a defrost heater because it is simply a rod covered with clear plastic.
Also there is a condenser in the compressor compartment just left of the compressor but nearer to the wall of the refrigerator. I have seen a printing in a repair help “Change suggested”. It did not say change if bad. Why such a suggestion if it may still be good.
Also how can I test the defrosters for efficiency?
Thanks for your help.
SublimeMasterJW
#2 Posted : Wednesday, July 16, 2008 12:58:40 PM(UTC)
SublimeMasterJW
The temp control,light, and defrost control are all neatly tucked together into one package in the fresh food compartment. Remove the 2 screws holding the console and it will drop down exposing the the defrost timer. If your serial number starts with a 10 then you have an adaptive defrost control which is probably 50 bucks. I would make sure the heater and defrost thermostat are working first. More than likely it is the heater. They are made of glass 20 inch's long and do fail quite often. While you are at it you need to replace the defrost terminator thats the small disk that attaches to the the glass tube and shuts it down when the temperature gets warm enough to melt the frost.
tino2003
#3 Posted : Wednesday, July 16, 2008 1:28:47 PM(UTC)
tino2003
Thanks so much for your prompt reply.
I see a console that holds the light bulb. If that is what you are referring to it has 3 screws. This is a Magic Chef Model no CTN1511GEW.
Tino
SublimeMasterJW
#4 Posted : Wednesday, July 16, 2008 6:14:07 PM(UTC)
SublimeMasterJW
Thats it.Three screws.
tino2003
#5 Posted : Wednesday, July 16, 2008 10:28:22 PM(UTC)
tino2003
Thanks again.
I see all that you mentioned but how do I test these to find out if they are functioning or not. I feel that the culprit is eitherthe Defrost Heater or Defrost Thermostat Assemply. What do you think?
A diagram was in the console but I don't understad that at this moment.
Tino
SublimeMasterJW
#6 Posted : Friday, July 18, 2008 10:07:45 AM(UTC)
SublimeMasterJW
Get an ohm meter or get a flash light and run 2 wires out of it so when you touch the wires together the light will come on(poormans meter) Then you should be able to check each component for continuity. You can get an old lamp cord and put aligator clips on the heater and briefly power it up to see if it comes on. The terminator needs to be placed into a freezer for 2 hours and then it should have continuity. When it warms up it opens and shuts down that heater so you won't melt the ice box.
tino2003
#7 Posted : Saturday, July 19, 2008 6:21:42 AM(UTC)
tino2003
Thank you again. I am not too clear on much of this section. What might a terminator is? And it sounds as though when I connect the alligator clips it will light up because you can't see heat. Maybe you can re-phrase the paragraph since I am a novice.
:mad: You can get an old lamp cord and put aligator clips on the heater and briefly power it up to see if it comes on. The terminator needs to be placed into a freezer for 2 hours and then it should have continuity. When it warms up it opens and shuts down that heater so you won't melt the ice box.
SublimeMasterJW
#8 Posted : Sunday, July 20, 2008 4:59:32 PM(UTC)
SublimeMasterJW
To defrost the freezer we use a heater. This heater is powerful.It only takes a few minutes to do its job. This heater will burn down the house. So the terminator kills this heater before it does a meltdown. The terminator will close contacts and allow the heater to engage at 25F. When the evaporator space reach's 50 degrees the terminator kills the power. Why? Because the defrost cycle lasts for 21 minutes. Then the compressor kicks in and begins another grueling 8 hour day.
tino2003
#9 Posted : Monday, July 21, 2008 12:10:28 AM(UTC)
tino2003
I cleand something under the frig that right of the compressor and has a fan blowing air into it. Left about 7 inches of space between the wall and the frig. It has been woking fine since. Do you what I am talking about and what it is. The frig don't run 8 hours though maybe it is because I don't open it regularly?
Why don't you tell me where the terminator is because I see no such thing in diagrams i have seen. Would really like the location of the terminator.
Thanks again.
SublimeMasterJW
#10 Posted : Monday, July 21, 2008 6:43:49 AM(UTC)
SublimeMasterJW
check it out the terminator is a small thermo disk wired directly to the heater with one wire:a water valve double.jpgfind the heater up in here and the little bitty terminator will be attached to it with a wire.It looks like this:dryer coil kit.jpg
SublimeMasterJW attached the following image(s):
GE bottom freezer model #: PFE28KBLTS not cooling well and no ice (Refrigerator & Freezer Repair)
by Danny1976 6/7/2024 12:43:43 PM(UTC)
GE bottom freezer not cooling well and no ice (Refrigerator & Freezer Repair)
by Guest 6/7/2024 7:31:51 AM(UTC)
Kenmore 106.74203402 fridge/freezer not cooling (Refrigerator & Freezer Repair)
by ryancg 5/26/2024 7:58:26 PM(UTC)
Electrolux fridge compartment not cooling, freezer is cold (Refrigerator & Freezer Repair)
by Minthook 4/22/2024 8:17:01 AM(UTC)
kenmore/lg fridge not cooling (Refrigerator & Freezer Repair)
by rleescott 4/16/2024 4:52:09 AM(UTC)
Monogram side-by-side not cooling - Ice builds up on Evaporator Fan (Refrigerator & Freezer Repair)
by 95ireland 3/11/2024 6:22:51 PM(UTC)
Mabe MBC12GAZASS Not Cooling (Refrigerator & Freezer Repair)
by MKDrepair 2/5/2024 5:57:08 AM(UTC)
GE GSS23QSTA not cooling after power outage (Refrigerator & Freezer Repair)
by sfarid123 12/19/2023 7:39:47 AM(UTC)
LG Refrigerator not cooling; compressor clicking. (Refrigerator & Freezer Repair)
by pmrowley 11/8/2023 7:07:53 AM(UTC)
Ge Monogram Integrated Top/Bottom Not Cooling ZICP360NXLH (Refrigerator & Freezer Repair)
Belarus grundyv2 10/7/2023 12:48:51 PM(UTC)
GE botom freezer not cooling (Refrigerator & Freezer Repair)
by Dieselista 10/6/2023 5:39:30 PM(UTC)
Whirlpool WRV986FDEM00 is not cooling (Refrigerator & Freezer Repair)
by Find a fix 9/23/2023 4:03:34 AM(UTC)
Jenn-air refrigerator not cooling (Refrigerator & Freezer Repair)
by pke 9/20/2023 4:18:40 PM(UTC)
Samsung family hub freezer not cooling (Refrigerator & Freezer Repair)
by foster1447 8/20/2023 2:36:12 PM(UTC)
Whirlpool Refrigerator cooling intermittently or not cooling at all (Refrigerator & Freezer Repair)
by lsitnj 8/12/2023 3:39:26 PM(UTC)
2 Pages12>
