After using self cleaning feature the built-in oven and now the oven will not bake or broil. I did all the steps unplung, reset etc. etc. wondering if if is the thermostat.
Thanks Darrell
Originally Posted by: johnsoncrew ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) After using self cleaning feature the built-in oven and now the oven will not bake or broil. I did all the steps unplung, reset etc. etc. wondering if if is the thermostat.
Thanks Darrell Most likely, it is the hi limit thermostat. Part number: AP3885687
They have a tendency to open in a self clean cycle,and they are a "one shot"design. You'll need to remove the oven from the cabinet to access the thermostat located on the back of the oven cavity. You'll also want to check your door gasket for a proper seal when the door is closed. And the blower motor when it's in the broil cycle, to see if it runs and circulates the air. Good Luck, :cool: :cool: :cool:
