gmanks
#1 Posted : 14 years ago
gmanks
Dryer timer buzzer won't stop unless door was opened or turned to new dry cycle. Replaced the timer but same issue, buzzer won't stop. What next?
#2 Posted : 14 years ago
Sounds like the buzzer is the culprit.
- The buzzer Part number: AP3019850
gmanks
#3 Posted : 14 years ago
gmanks
Turns out it was the Start push button switch. Dryer would start as soon as you turned the timer to a new cycle. Contacts were stuck, so cleaned them up and that did the trick. Will need to get a new one in the near future.
#4 Posted : 14 years ago
I'm glad you were able to diagnose and fix the problem. Good job!
Thank you for the feed back.
Guest
#5 Posted : 3 years ago
Guest
I have the same problem with my Kenmore.
I need to know what contacts he is talking about?
ThatGuy
#6 Posted : 3 years ago
ThatGuy
Hes talking about the contacts inside the start switch being 'welded' together. I've seen it happen a couple of times.
