TJ68
#1 Posted : Thursday, September 9, 2010 10:28:53 AM(UTC)
TJ68
I ordered a new timer for my Maytag Atlantis gas dryer, model #MDG7460AWQ, because it would no longer turn on when the timer knob was pulled out. Other than that, it was running fine at the time. I installed the new timer and it would not shut off, whether it was in timed mode or the dampness detection mode. I called in and a new timer was sent to me. That timer is doing the same thing, it won't shut off in either mode. It dries fine, but it will run until manually stopped. Is there something else wrong or do I have another bad timer?
And the vent is clear, I checked that again last night.
Gary/APP Team
#2 Posted : Friday, December 16, 2011 11:07:36 AM(UTC)
mattt
Groups: Guests
Hello TJ. It sounds like the door switch AP4319999'); return false; " style="text-decoration:underline;" href ="http://www.appliancepartspros.com/partsearch.aspx?pn_=AP4319999" target="_blank">Part number: AP4319999
AP4319999" target="_blank"> AP4319999" border="0" alt="Part number: AP4319999" title="Part number: AP4319999">
AP4319999">
has gone bad,if when you open the door the unit keeps running, this is a sure signof a bad door switch. Thank you and good luck!
