2 Pages<12
#11 Posted : Wednesday, September 8, 2010 11:59:39 AM(UTC)
Scott,
After you replaced the water filter you have to dispense 2 to 3 gallons of water to get rid of any air from the system. Did you do it?
scott805
#12 Posted : Wednesday, September 8, 2010 2:55:11 PM(UTC)
scott805
Hi Gene, thanks for the response. Yes, I did “attempt” to dispense the 2-3 gallons, but the flow went to a trickle after about ¼ gallon. I pressed on for the better part of 30 minutes and got maybe about 1-2 gallons in that time. The flow is REALLY slow. I also tried removing the new filter and put the plug in to make sure I didn’t have a bad filter, but the flow was still awfully slow.
#13 Posted : Thursday, September 9, 2010 7:59:36 PM(UTC)
Scott,
Check the pressure in the incoming water line and the screen in the water inlet valve.
2 Pages<12
