dkjmom
#1 Posted : Tuesday, September 7, 2010 11:39:38 AM(UTC)
dkjmom
Views messages in topic : 2
Is there anyway I can fix this myself or is this something that should be handled by a professional?
#2 Posted : Tuesday, September 7, 2010 2:59:10 PM(UTC)
Can you be more specific on the problem?
What and how the washer does and what and how it does not?
dkjmom
#3 Posted : Wednesday, September 8, 2010 5:53:19 AM(UTC)
dkjmom
The washer runs everything normally until the spin cycle. You can hear the motor running but the cylinder doesn't spin. The water just drains out the bottom leaving the clothes extremely wet.
#4 Posted : Wednesday, September 8, 2010 1:27:36 PM(UTC)
Try to open and close the lid when the washer comes to that point. If it would spin, the problem is a bad timer. Unfortunately this part is no longer available.
pipelayer_99
#5 Posted : Sunday, December 9, 2012 12:37:16 PM(UTC)
pipelayer_99
Our washer will run through all the cycles but doesn't always high spin. A couple times we will move the dial to high spin(after the cycle is done) and the motor will run but won't spin. I will shake/move the basket by hand and the high spin usually works. Is it a stuck brake, bad clutch or switch?
FarmingtonWife
#6 Posted : Sunday, December 9, 2012 1:04:02 PM(UTC)
FarmingtonWife
Tried what have suggested above but did not help. What else to do.:confused:
#7 Posted : Monday, December 10, 2012 12:36:06 PM(UTC)
Hello,
You may want to start the troubleshooting from checking the drive block. You can find more useful information in one of our previous threads: http://forum.appliancepartspros...ir/373-not-spinning.html
Here are the breakdown diagrams and Parts for Whirlpool LSQ8000LQ3 Washer - AppliancePartsPros.com
#8 Posted : Monday, December 10, 2012 12:38:38 PM(UTC)
What is the complete model number of the washer?
3 year old top loading washer won't spin clothes dry (Washer Repair)
by craig100 3/15/2024 9:35:49 AM(UTC)
Samsung washer won't spin (Washer Repair)
by Guest 1/8/2022 10:56:39 AM(UTC)
Maytag Washer won't spin or complete cycle - FIXED! (Washer Repair)
by jimjokjv 10/1/2021 10:08:04 AM(UTC)
Whirlpool WTW4815EW1 Washer Won't Spin or Agitate (Washer Repair)
by dann1551 4/7/2021 8:42:00 AM(UTC)
Maytag performa washer won't spin. It drains and i can hear the motor but tub appears stuck. (Washer Repair)
by Brittrepairs 12/21/2019 7:47:28 PM(UTC)
Whirlpool LSN2000LW Washer Won't Spin, Buzzes (Washer Repair)
by Robb235 2/21/2019 4:21:02 AM(UTC)
Washer won't spin out. (Washer Repair)
by DJChad818 10/26/2017 9:47:20 AM(UTC)
Washer won't spin (Washer Repair)
by Fingers123 10/22/2017 1:43:41 PM(UTC)
Washer Won't Spin (Washer Repair)
by je00409 9/5/2017 11:00:04 AM(UTC)
Washer won't spin or agitate (Washer Repair)
by dhughes 4/1/2017 10:17:04 AM(UTC)
Whirlpool belt drive washer won't spin. (Washer Repair)
by weswoodallz21 3/21/2017 7:08:08 AM(UTC)
Maytag Washer won't Spin just Hums (Washer Repair)
by bnweth 1/4/2017 8:29:35 PM(UTC)
Whirlpool washer won't spin or drain (Washer Repair)
by ronaldjp1 1/3/2017 2:58:09 PM(UTC)
maytag washer won't spin fast (Washer Repair)
by benp1 12/21/2016 5:14:31 PM(UTC)
by lmhansgen 8/31/2016 10:19:23 AM(UTC)
