sharonrsewing
#1 Posted : Sunday, August 29, 2010 9:27:46 PM(UTC)
sharonrsewing
The light on my range hood doesn't work. Changed bulb and that didn't help. The fan still works. Do I need to replace the switch? Does anyone know if the bulb holder is part of the replacement mechanism? Also, how difficult is it to do all this yourself?
#2 Posted : Monday, August 30, 2010 2:22:17 AM(UTC)
Replacement parts for WHIRLPOOL RH4730XDZ0 | AppliancePartsPros.com
Here is a wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%20883171.pdf
Cannot say. You would have to check the switch with a meter.
Looks like the bulb holder is a separate unit.
Should not be that difficult.
Also the first thing I would do is check that the replacement bulb you are suing has continuity. Would not be the first time that a bulb is no good right out of the box and ripping the hood apart to find out it does not have a problem is a lot of extra work.
Check the inside of the bulb holder to be sure the connections are OK.
Be sure to shut power off to the unit when working on it.
sharonrsewing
#3 Posted : Monday, August 30, 2010 7:18:24 AM(UTC)
sharonrsewing
Thanks denman, good advice. I did check the bulb and it is okay, but didn't check bulb holder, so thank you for that suggestion. I'll do that next then get my son to come over with his meter.
Sharon W (Oven Repair (including Ranges and Cooktops))
by Sharon W 12/12/2009 4:42:50 AM(UTC)
Sharon (Oven Repair (including Ranges and Cooktops))
by srsmith 8/5/2009 9:13:33 AM(UTC)
