7 Pages«<34567>
DEA7
#41 Posted : Tuesday, September 15, 2009 8:09:20 AM(UTC)
DEA7
I have the same problem as you with the rs2534ww.Were you able to remove the heater from the evaporator and how does the evaporator come off?I know you can't remove it entirely because it is filled with coolant but do i need to unfasten it to replace the heater?Is the coiled heater mainly in front of the evaporator?
jay1028
#42 Posted : Tuesday, September 15, 2009 5:51:37 PM(UTC)
jay1028
wolf05, did you get anywhere with the defrost heater for the fridge?
RNick
#43 Posted : Sunday, March 7, 2010 11:12:48 AM(UTC)
RNick
Search for other posts by me and JMKinch. The heater can be replaced without breaking the lines. I took pictures of the whole repair and will post when possible. Old heater was open circuit. New heater ohmed out at 95 ohms. Take your time and you will be OK. The trickiest part is cutting the head off a rivet holding the old heater onto the assembly. Use a bare hacksaw blade in hand to do it inside the fridge. On the new heater/ evaporator assembly, the rivet can be drilled.
RNick
#44 Posted : Tuesday, April 6, 2010 6:17:22 PM(UTC)
RNick
Finally. I found the time to get this posted!
Samsung Refrigerator Heater Repair (RN's site)
:D
dek1000
#45 Posted : Saturday, April 17, 2010 3:13:06 PM(UTC)
dek1000
I've been frustrated by my Samsung RS2545SH, a Costco purchase that I drooled over for a year or more until I could finally find a place to put it. I mean, dual evaporators -- What a great innovation. If only they had included reverse freon flow for hot-gas defrosting, then none of these icing up issues would have been created. Okay, they could have been, meaning that you would have had more severe issues, like blocked freon lines, or a dead compressor. But still: they combined the evaporators with the defrost heaters?
At first, I had water dripping on my floor because the drain line was blocked, which, according to some sites, meant that a drain heater was dead. Not sure I have confirmed that was true by looking at the schematics and all. But a towel on the refrigerator floor and periodic squeezing it out was enough of a solution. Then the water would not come out of the dispenser -- probably a frozen water line, I figured; never thought it might be a frozen water tank. Then one night, a 65 degree refrigerator with 1 degree freezer. Time to get serious about diagnosing the problem. Took out the shelves and drawers and removed the back panel of the refrigerator: one block of ice.
So here I am at this great site, reading everyone's related problems, and now have a start as to how to fix it all. I hope it's not a bad defrost heater, but if it is, I'll do the fix described here: pull a heater from a new unit and swap it with my bad one without having to solder and evacuate and all that. At $49 for the part, not bad at all. The other solution is return it to Costco for my money back. But at, what, 350 pounds? I'm not ready for that bit of moving, not just yet anyhow.
Someone here suggested buying a defrost heater made for some refrigerator: I'd prefer to do that, actually, like wrapping heater strips on your outside water lines for the winter. Does anyone have a good suggestion as to which brand and part number would be a best solution for that? I'd prefer the lesser hassle of doing that if it was thought to be doable and there was a good part out there. I'd be happy to take the chance and report back if it worked, assuming it is indeed my defrost heater.
But before I forget, thanks, RNick, for posting your results.
Thanks for everyone's great input. I'm thrilled to find a forum where even the novices are treated well by the experts.
Cheers!
osmotw
#46 Posted : Sunday, May 9, 2010 12:12:15 PM(UTC)
osmotw
THanks RNick! I swear if I have to borrow my wife's hair dryer to defrost my Samsung SxS one more time she's going to divorce me!
Going to check the circuits today and hopefully fix it for good next weekend. I have an RS267LBSH with the wireless tv in the door. It's a great fridge and would be a shame to replace the whole thing for something this little.
Will post how it goes!
sduh2010
#47 Posted : Tuesday, June 22, 2010 2:27:04 PM(UTC)
sduh2010
Really help thread I found. I have a Samsung refrigerator (RS2545SH) with the same defrost problem: the fridge coil is covered by ice and the fan is blocked by ice. it can not make cool on the fridge side. It will work 3-4 days after removing the ice.
I request a repair. Do you think this repair will be covered by the warranty?
dek1000
#48 Posted : Saturday, July 10, 2010 8:47:56 AM(UTC)
dek1000
I'm having another typical repair: solid block of ice at the bottom on the evaporator in the refrigerator. I have it all thawed out, but for the life of me, I can't seem to get the drain line cleared. Perhaps I've just gotta wait for an ice plug to thaw. Looking at it from the back, above the subcondenser, it goes up and hooks a left (looking at it from the back), before going up. From the inside, I'm guessing it does down and turns left (looking from the front). It would seem that if that line was clean, the water would drain and this ice dam would never form. I omned the evap defroster, and it's okay. However, the water tank heater looks to be an open circuit. Would explain why the water doesn't want to come out. This happens about the time that the water starts to pool on the bottom on the refrigerator compartment, which eventually leads to the refriderator section no longer cooling. So here I am, parts all over the floor, waiting to put it back together but would like to have that drain cleared. Any easy way besides patience? Hot water isn't working. If I have a clog that's ice and dirt, this could take too long. I don't want to have to empty the freezer. I love this unit, but it's like owning a VW: these "little" repair problem will lead me to kill it some day.
skywolfy
#49 Posted : Tuesday, August 17, 2010 8:20:42 PM(UTC)
skywolfy
i use a cow needle / syringe with a small rubber hose attached, primitive i know. warm water in the syringe is forced directly down the hole and is way better than a drill bit. bores like crazy. i have changed a heater before via the new evaporator method,removed and replace only the heater. i removed the rivit with a dremel tool, be careful bigtime!! i have a wierd ice buildup at the top of the evaporator, builds up hits the fan, stops it and we know the story. i am a tech so i manually entered defost mode. heater worked so...why the ice. the fan also worked before and after. premature defrost termination?? bad sensor telling the pcb to terminate defrost. entire evap is not covered. Hope it not a freon issue. Any help??
jay1028
#50 Posted : Wednesday, August 18, 2010 1:09:37 PM(UTC)
jay1028
I would check the defrost thermistor that is attached to the top of the evap coil. I have replaced two of them. Both instances, the resistance was stuck at around 2k ohms. That was telling the motherboard that the temp was high and to terminate the defrost cycle. I have read in a European forum that there is an improved version of the thermistor that is in a black colored case vs the white. I don't know what goesw wrong with these, they look to be sealed well enough. I opened one up and it never returned to the proper resistance at room temp. I have been lucky so far that my deforst heater is still ok. I have a spare on hand because I know that it is only a matter of time before they all fail.
Guest (10)
7 Pages«<34567>
