juneschild
#1 Posted : Tuesday, August 17, 2010 10:34:51 AM(UTC)
juneschild
My dryer makes a horrible screeching noise whenever it runs. I figure it's the belt or the rollers or bearings, but I am having trouble pinpointing the source since I can't seem to get the cabinet apart to get to the drum. I was able to remove a couple screws and get a peek at the top of the drum and the belt, which appeared to be fine. I know that the rollers are located under the drum, but the darn cabinet seems to be connected everywhere, no matter how many screws I remove. Any suggestions would be appreciated. Thanks!
#2 Posted : Wednesday, August 18, 2010 1:14:54 AM(UTC)
Here is the parts breakdown includes the wiring diagram.
Replacement parts for CROSLEY CDE6505W Dryer - Ele | AppliancePartsPros.com
Here is a manual
http://www.servicematters.com/maytag_library/docs/16026315.pdf
Check the rear support rollers, the idler wheel, the motor and the front glides.
Also check the belt for cracks.
Since you have it open you might as well check/clean everthing else. Basically give it an ovehaul.
Also a good time to clean/check your vent system.
Noisy Dryer (Dryer Repair)
by family guy 8/24/2013 3:12:08 PM(UTC)
Loud noisy dryer through whole cycle but works (Dryer Repair)
by joannesnauta 3/8/2012 10:04:17 AM(UTC)
noisy dryer when running sqeaky and vibrates (Dryer Repair)
by Dale Powers 5/11/2011 12:41:42 PM(UTC)
Noisy dryer (Dryer Repair)
by pncope29@gmail.com 10/11/2010 4:49:25 PM(UTC)
noisy dryer (Dryer Repair)
by lramsey00 1/20/2009 3:43:19 PM(UTC)
by ge1209 11/13/2008 1:42:22 AM(UTC)
by marti73 10/28/2008 9:27:57 AM(UTC)
by tmta4irish 7/24/2008 4:17:52 PM(UTC)
by Davyd 5/27/2008 5:06:55 PM(UTC)
by james steward 3/17/2008 9:16:56 AM(UTC)
by dan523 3/4/2008 9:42:10 AM(UTC)
Noisy Dryer - Sounds like we are polishing rocks when it is running (Dryer Repair)
Belarus this old house 1/26/2008 5:43:40 AM(UTC)
noisy dryer when on (Dryer Repair)
by ellashoe 10/21/2007 8:58:02 PM(UTC)
