larrs27
#1 Posted : Sunday, August 15, 2010 12:10:58 PM(UTC)
larrs27
When I turn on the AC the compressor kicks on and blows cold air but only for about a minute then it kicks off and won't come back on unless I turn the unit off and let it set for about ten minutes. Then it just does the same thing again. Could this be a thermostat or capacitor problem, or is there something wrong with the compressor? It's Sunday and 95 in the shade. Help me please.
Thank You.
Larrs27
larrs27
#2 Posted : Monday, August 16, 2010 7:55:08 AM(UTC)
larrs27
No help? No suggestions? :confused:
larrs27
#3 Posted : Wednesday, August 18, 2010 2:07:46 PM(UTC)
larrs27
So much for getting any help here. :(
marknat
#4 Posted : Friday, August 20, 2010 3:31:29 PM(UTC)
marknat
Thank You.
Larrs27
Note: This work should be done by someone who possesss EPA certification.
Check system operating pressures with manifold gauges and you will probably find the system is low on refrigerant. Find leak and repair. Vacuum refrigerant lines and recharge system to proper subcooling or superheat.
icehouse
#5 Posted : Sunday, August 22, 2010 4:35:58 PM(UTC)
icehouse
There is an electrical problem possibly the capacitor or worse case the compressor.
Guest (5)
