AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Dryer lights are on, but just hums when I push start
I have a 2 year old dryer and I just took out a load of laundry and when I put in new load, it wouldn't start. Lights are all working correctly, but just makes a buzzing noise when I push start. Help!
Sounds like a motor problem.
Try turning the drum in the correct direction to see if perhaps it is jammed.
This may take 2 people. Open the door and manually close the door switch. Push the start button and at the same time rotate the drum in the correct direction. Watch your knuckles in case it start up. If it does start then the motor is the likely culprit. |
THIS FORUM IS DEAD!!!!!!! |
Dryer Repair
