It doesn't go through the cycles. It will stop before the rinse cycle, then i have to reset it to rinse, but then it will stop before the spin cycle and i have to prompt it again. It is very frustrating because i have to keep going in and switching it to the next cycle. What would make it keep stoping before all 3 cycles are finished?
Originally Posted by: cmalagisi  It doesn't go through the cycles. It will stop before the rinse cycle, then i have to reset it to rinse, but then it will stop before the spin cycle and i have to prompt it again. It is very frustrating because i have to keep going in and switching it to the next cycle. What would make it keep stoping before all 3 cycles are finished? It could be a bad lid switch or a bad timer. In order to provide most accurate advise we need the complete model number of the washer. Gene.
Gene. The model # is RAX7245JQ0. Thanks
Unplug the power cord. Open the control panel, unplug the lid switch harness plug and bypass the lid switch (#9 on the break down diagram). Run the washer and see if it'll work properly. Post the result. Gene.
