How do you remove the Lid Switch? What is the part number for the Lid Switch?
Originally Posted by: Larry G ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) How do you remove the Lid Switch? What is the part number for the Lid Switch? Larry, Access to the lid switch assembly is through the control panel. Unplug the line cord first. Remove the 2 inner screws on the corners of the top of the control panel trim and pull the top towards you. The lid switch is mounted with 1 screw that you will need to remove in order to lift and remove the tabs from the slots in the top. When you install the new switch assembly, make sure the metal tab sticking up through the top has to be between the plastic switch body and the button of the switch. Open the lid 1/4 to 3/8 of an inch,and slide the assembly towards you until the button clicks and secure the assembly in place(tighten the screw). Now switch the wires from old to new switch, reinstall panel and test operation. Part number: AP4026359
:) :cool:
