3 Pages<123
Tye
#21 Posted : Tuesday, June 24, 2008 2:20:53 PM(UTC)
Tye
It doesn't shut off everytime. You have to turn it around and make it click about 3 times before it will shut everything down.
When I opened up the back of my freezer their was frost further up, but not all the way to the top. It is the worst at the bottom and goes up from there.
abadfish66
#22 Posted : Tuesday, June 24, 2008 2:27:45 PM(UTC)
abadfish66
Ok, so if I read this right worse means the bottom coils above the heater were completely covered, a solid chunk of ice, but the rest of the coils above the other heater seamed to be ok, there was frost on the coils but not a big ice chunk? Sorry if I'm not understanding you correctly.
Tye
#23 Posted : Tuesday, June 24, 2008 2:30:12 PM(UTC)
Tye
The coils above the bottom heater were mostly solid ice. The coils above the other heater were very frosty. The coild at the top seemed to be what they should be.
abadfish66
#24 Posted : Tuesday, June 24, 2008 2:38:02 PM(UTC)
abadfish66
Good, now I definatly believe your heaters or defrost termination thermistat are at fault. If you order that part I gave you the # to, you should be fine, it is a heater kit that includes the defrost thermostat already wired in. Since you manually defrosted the coils, put everything back together and post temps tomorrow, also you should be fine for about 7 days before you would have to defrost again, plenty of time to order the part and have it shipped.
Tye
#25 Posted : Tuesday, June 24, 2008 2:52:35 PM(UTC)
Tye
My question is this...Is that white plug the heater thermostat?
Tye attached the following image(s):
Tye
#26 Posted : Wednesday, June 25, 2008 3:29:31 PM(UTC)
Tye
So todays temps are:
Fridge:34
Freezer:10
abadfish66
#27 Posted : Wednesday, June 25, 2008 4:09:40 PM(UTC)
abadfish66
Going in the right direction :) That white wire is just that, a wire. Your defrost thermostat is clipped onto the evap usually at the top and is a round device siver in color. Probably a blue and pink wire attached to it.
Tye
#28 Posted : Wednesday, June 25, 2008 5:55:56 PM(UTC)
Tye
So I would need to buy that and the heaters
abadfish66
#29 Posted : Wednesday, June 25, 2008 6:11:14 PM(UTC)
abadfish66
I would, should not cost too much
Freezer & Fridge not cold - coils cold, evap fan works but not running (Refrigerator & Freezer Repair)
by bootpdx 1/6/2015 9:51:56 AM(UTC)
Top of freezer & fridge not cold (Refrigerator & Freezer Repair)
by shacook 4/27/2010 9:43:54 AM(UTC)
3 Pages<123
