I Have A 2006 Kenmore Electric Dryer Model # 66652. There Are Two 30 Amp Fuses In Fusebox. Dryer Spins Fine But Timer And Heat Fuse Blows After A Few Minutes? Any Help Would Be Greatly Appreciated!! Thanks!:) :(
Most likely there is an air flow restriction in the exhaust line and/or inside air ducts, causing overheating. Possible a problem with the blower wheel. For more accurate advise we need the complete model number of the dryer.
