rjd222
#1 Posted : Monday, June 23, 2008 7:44:58 AM(UTC)
rjd222
When washer is agitating the tub is trying to turn & making a loud screaching sound. Tub spins fine during spin cycle.:confused:
Help please
okbobcats
#2 Posted : Tuesday, June 24, 2008 3:51:44 AM(UTC)
okbobcats
Your brake is slipping. could be oil on brake or shaft on the bottom pulley stuck and not allowing brake to set all the way.
rjd222
#3 Posted : Tuesday, June 24, 2008 10:06:15 AM(UTC)
rjd222
Thank you for getting back to me.
Will this mean removing & dismantling the transmission. Would it be a major repair job?
okbobcats
#4 Posted : Tuesday, June 24, 2008 3:08:09 PM(UTC)
okbobcats
take off the front panel. to see if it oily you get get to the shaft from under neath just tip washer back and take apart to see if it dirty or wornen
Maytag washer making noises (Washer Repair)
by HeatherMP 4/11/2011 5:18:49 PM(UTC)
