micro makes buzzing noise when turned on. seems to be comming from part called the stirrer. also starts running when you partily open top door latch.
Looks like there are two separate problems: the stirrer motor behind the top grill) and the interlock door switch (inside the control compartment on the door frame). - The part number for the stirrer motor is AP2151223 - The part number for the interlock switch is AP2151217 Gene.
