tdfreeman
#1 Posted : Tuesday, August 3, 2010 9:48:04 AM(UTC)
tdfreeman
Not sure the brand says Imerial on door. The upper portion of the door does not adhere when closed. It has a gap which causes the upper part of the freezer to have ice build up rapidly. I don't know if I just need a new seal or if I need the inner part of the door. Trying to find out what parts I need to buy.
:confused:
#2 Posted : Tuesday, August 3, 2010 12:07:45 PM(UTC)
Is the door gasket physically broken?
Is the door twisted?
Here are the breakdown diagrams and Door replacement parts for FRIGIDAIRE UL4000ECW2 | AppliancePartsPros.com
tdfreeman
#3 Posted : Tuesday, August 3, 2010 1:32:59 PM(UTC)
tdfreeman
No the gaskit is not broken and the door does not seem to be bent or twisted. The top of the door just does not seal anylonger. So I don't know if I need to order just the gasket or the middle portioin of the door. They seem to be two seperate pieces the gasket being 124. and the middle part being 185.59
#4 Posted : Tuesday, August 3, 2010 1:44:37 PM(UTC)
Before order any parts you may want to try to adjust the gasket using a hair dryer. After you will get the door sealed properly, tape it closed for a few hours.
hotfire97
#5 Posted : Wednesday, October 19, 2011 2:34:03 PM(UTC)
hotfire97
did you ever get this fixed my imperial does the same thing?
Guest
#6 Posted : Wednesday, June 9, 2021 5:27:33 AM(UTC)
Guest
Groups:
My name is Mike I'm having the same problem, with my gasket the hing side is good bottom good handle side just below the lock upward it starts to gap about 1/2 " continues to the hing, so if I use a hair dryer and strap the door this should cure the problem I see where the gasket is shrunk in if not ill order a new gasket
Guest (6)
Imperial Commercial Upright Freezer (Refrigerator & Freezer Repair)
by jmmullin 5/31/2015 5:32:52 AM(UTC)
